How to control the web server application through LabVIEW?
I have a device controlled by Web Server application. I am opening http://192.168.255.69:12450 address. It will open the internet Explorer with the field for control the test and do the test(Screenshot in attachment), It is a manual process. I need to automate this process using labview.
Please help me to do this with labview.
Rathnam.M(CLAD),
Nokia Siemens Network
(3,884 Views)
Hi Rathnam.M,
what happens if you press start? How will the selected values be send to the device. Is it a GET or POST request? If it is GET, then you can build the new header line with the values you need, otherwise you have to build the correct content.
Mike
(3,880 Views)
See this thread
LabVIEW 2012
(3,859 Views)
Hi Mike,
When I press start, it will execute the test in the device and shows the test result value. It is Get request.
Rathnam.M(CLAD),
(3,843 Views)
Hi Rathnam.M,
if it is GET, then you should see the used parameters in the address field. If this is the case, the you can call the side as seen in the example from Steve.
Mike
(3,832 Views)
@Rathnam.M wrote:
Hi Mike,
Are you sure it is a GET? If so then as Mike says the parameters are encoded in the URL. Just change the POST in the string to GET.
But it really looks like it is a POST because of the form. Can you post the source? Just open the webpage and do a file/save and attach the file.
LabVIEW 2012
(3,818 Views)
