How to connect pressure transmitter to labview
 I am new to the Lab view , so i need to connect the pressure transmitter to Lab view 2014 version .
The transmitter Omega PX119 series  4-20 mA is the out range. The input will be how and what are required to connect to lab view . Also attached the pressure transmitter data sheet
(2,697 Views)
Hi mijumcn,
the sensor is a piece of hardware, and LabVIEW is software.
To "connect" both you need some kind of DAQ device!
Do you have one? Which?
You need a power supply for your sensor(s). I also recommend some accurate shunt resistors (between 220 Ohm for 5 V measurement range and 440 Ohm/10 V range)…
(2,689 Views)
Hello sir,
  Currently i didn't have any DAQ device. So kindly advice which model will be suitable
(2,669 Views)
Hi mijumcn,
You can use a simple USB600x device from NI. Or even a small Arduino!
It all depends on your requirements regarding accuracy, repeatability, resolution, sample rate, …
(2,665 Views)
