How to use MPU 6050 with NI 6000 in labview
how to acquire data of X,Y,Z axis of   MPU  6050 accelerometer  with NI 6000  in :Labview.
(2,600 Views)
Accepted by topic author chaitanya_krishna
Hi Surya,
those MPU6050 accelerometer only supports I²C communication.
You're out of luck with your USB6000: use other hardware!
(2,540 Views)
i am using urdino uno board still i amnot unable to get the data using labview.
(2,524 Views)
Hi Surya,
Because of which reason? Do you get any errors?
I don't use LINX, so cannot comment on your VI.
I suggest to use the "ordinary" ArduinoIDE to let your Arduino read that sensor and send its data to its (virtual) COM port. Then use VISA functions to read the COM port from LabVIEW…
(2,519 Views)
Even i had tried that in aurdinoIDE still no response after initlization i2c then it goes for dmp initialization. stil i amnot able to get the data .all connections to uno is correct
(2,514 Views)
Hi chaitanya,
so there is a problem in the communication bus, or the devices you use…
Check them all!
(2,509 Views)
