How to comparing two 1D array and pull out the mismatched element insert into 2D array
Greetings.
I have two 1D arrays and I have a 2D array
first array - { a,b,c,d,e}
second array - {a,b,z,c,d,e}.
2D array -{name, vendor, type,number
                 abc,        efg ,     a ,   6,
                aaa,        rrrr,       b,     7,
                zzz,        tttt,        c,     6}
I want to pull out that element that is additional in the second array and insert it into 2D array under the type column in the last row. I am not able to find a solution. it would be of great help if anyone helps me in finding a solution.
Thanks in advance!
have a good you'all:)
(2,612 Views)
The adding to the 2Darray can be done in a dozen ways. It's not clear to me what exactly should be added, so this solution is just a general one that works.
(2,591 Views)
Thank you so much for the reply:)
The z element which is present in the second array should be added to the type column leaving other columns blank.
name  vendo type numb
aaa     bbb      a    6
cccc    rrr        b    7
eee     zzz      c     8
www    qqq     d     5
uuu      iiii        e     9
                       z
similar to this I have again 2 - 1D array so I should search in the similar manner and find that additional element and add it to the 2D array
aaa                        bbb      a       6
cccc                        rrr        b       7
eee                         zzz      c       8
www                       qqq      d       5
uuu                          iiii        e      9
new-element                       z
(2,583 Views)
Simply remove the "??" from the string, you'll get empty strings.
If the input array has the data (I only copied the titles), what I've posted does this.
aaa                        bbb      a       6
cccc                        rrr        b       7
eee                         zzz      c       8
www                       qqq      d       5
uuu                          iiii        e      9
new-element                       z
Not sure what you mean.
You also have 1D arrays for the name column? I'd hope the added element in that array has the same index as in the type array.  So you can simply use the index to get the new name:
(2,571 Views)
