How to choose some elements containing some Specific alphabets from an array?
for example, an array contains the following elements: AA1 AA2 AAB CAA ABC   BBE  BAA  . I want to choose out the elements containing AA,that is
AA1 AA2 AAB CAA BAA. Can you give me the relevant procedures? thank you!
Message 1 of 13
(3,553 Views)
Look at Match Regular Expression.  I don't know enough about the coding format to tell you what the search code would be.
Of course just doing a search string for "AA" will give you whether it exists in a particular array element or not.
Message 2 of 13
(3,552 Views)
The actual element type as in the example.Thank you!
Message 3 of 13
(3,548 Views)
I don't see how you can do that without examinig each element of the array.
The examination could be done with regular epression.
If you are not anxious about the sequence of the result you can use parallizing of loops to take advantage of your multicore.
Gabi
7.1 -- 2013
CLA
Message 4 of 13
(3,521 Views)
I'm assuming his question is now solved because he did say "thank you."  He never asked any additional questions, so it must mean he understands what to do now.
Message 5 of 13
(3,507 Views)
".AA" matches any character string ending with AA, "|" or "AA." matches any character string starting with AA
Message 6 of 13
(3,489 Views)
thanks! I have solved it
Message 7 of 13
(3,470 Views)
what did you use to solve it? ...so that others may know.
Message 8 of 13
(3,463 Views)
as the picture
Message 9 of 13
(3,460 Views)
cool....then please mark that post as a solution and give kudos to those that helped  Smiley Wink
Message 10 of 13
(3,448 Views)
