How to change the column-header of a measurement file?
Whenever I use the "Write to Measurement File" express VI, LV creates an text file with extension  .LVM whose column-header looks like this:
X_Value    Untitled    Untitled 1    Untitled 2    Untitled 3    Comment
0.000000    0.000000    1.000000    0.000000    0.000000
1.015625    0.000000    1.000000    0.000000    0.000000
. (etc)...
How can I make it save more meaningful column-headers, instead of "Untitled", "Untitled 1", etc....?
The configuration screen of the express Vi is attached for reference....
Thanks!
(3,784 Views)
Hi emerino,
i think if you change the name of your signal, then the Header in your lvm file will change to the same name.
Mike
Message Edited by MikeS81 on 02-21-2008 03:25 PM
(3,773 Views)
How do I change the name of the signal?
(3,761 Views)
Hi emerino,
where do you get your data from? With the DAQ Assistent it is the channel name, with a simulated signal you can change the name button right.
Mike
(3,738 Views)
You can set the signal names by using Set Waveform Attribute.  On each of your signals, set an attribute whose name is "NI_ChannelName" and whose value is a string containing the signal name.  If you need more help, check out this post.
(3,732 Views)
Yes, I do use the DAQ Assistant to collect data from 2 channels, but then, before writing to the meas. file, I "split the signal" and based on the reading and some input data (from the user), I later use the "merge signals" to add the extra data and end up with 3 more columns (so total 5 columns....or 6 if you count the time)
(see attached file)
(3,697 Views)
