How to change color of negative points in waveform chart for log scaling
I have data that may be positive or negative and have a large dynamic range. I want to plot in log scale, so I want to abs() the data and then if it was negative, make it a different color. I saw this post from 2015 implying that I can't do that because the entire line has to be the same color, and they did some tricks with multiple lines: https://forums.ni.com/t5/LabVIEW/Change-point-color-in-graph-if-it-s-inside-a-certain-range/m-p/3193...
This seems weird though, because having negative data on a log scale in a different color is a fairly standard technique and I would have though that LV would have some les kludgy way to handle it.
Is there a way to color individual points in a chart via some sort of filter? Or, alternatively, can the waveform chart in some way "handle" negative data on a log scale via some config setting to just change the color and abs it?
(1,419 Views)
Accepted by topic author AlexGSFC
Hi Alex,
Simple solution: sort (and divide) your data into a "positive" and a "negative" part. Then put each part into its own plot, replace "missing" points by "NaN" data. Each plot will have its own color…
(1,352 Views)
Yeah, that is what they talked about in that other post I linked. I was hoping that there was a less kludgy way to do it. Having different colored points on a line seems like a fairly simple and standard thing, but I guess it is what it is.
Thanks!
(1,317 Views)
