How to build WSN program
I have developed the program for NI WSN 3214 but I am unable to deploy the code. When I run the code I get the following error.
[12:31:32] Status: Build Error.
Error message: Linker error occurred
Error Output:
error: cannot find file "libfirmware.a"
I have attached the error message screeshot.
Kindly help to solve this error.
Thanks in advance
(2,955 Views)
Did this happen before or it is the first time you use these WSN 3214 nodes? Other than the WSN 3214 (ID 2) that has a build error, did the others managed to compile? Have you tried just one only?
If the rest of the WSN 3214 node had the similar build error message, what is the NI WSN driver version are you using? Did you update the firmware of each WSN nodes?
Lennard.C
Learning new things everyday...
(2,682 Views)
