Programming batch modify properties of shared variables DSC Module
DSC module to establish a large number of shared variables, you need to modify the property values ​​programmed variables, rather than setting property values ​​when creating variables.
DSC module to build tens of thousands of shared variables, alarm limit properties of these variables need to be set after the software is released by the customers themselves, rather than set when you create the variable.
So many variables, how programming in the software interface can be set variable attributes?
(2,671 Views)
