How to avoid the numeric indicator to be set to zero when case structure is false?
The numeric indicator will be set to zero when case structure is false. I chose "Use Default If Unwired" for the blue hollow dot on the edge of case structure, otherwise error will come out if I didn't do anything thing with the little blue hollow dot. How to avoid the numeric indicator to be set to zero when case structure is false?
(3,785 Views)
Hi Jason,
use some shift registers to hold the values for those indicators...
(3,772 Views)
Accepted by Jason2018
Put terminal of the indicator inside the case structure, so the indicator will be updated only in one case
_____________________________________
www.azinterface.net - Interface-based multiple inheritance for LabVIEW OOP
(3,752 Views)
Problem solved. Thanks a lot.
(3,725 Views)
