Labview Exercise: Parking Fees
Hello, I'm trying to write a program that calculates the parking fees for customers who parked their cars in a city garage, assuming that no cars are parked longer than 24 hours. I'm having more trouble than I originally thought. Lets say the following is the parking rates for a garage: 0-1 Hours - $ 7.00
1-2 Hours - $ 8.00
2-3 Hours - $ 9.00
3-4 Hours - $10.00
4-5 Hours - $ 12.00
5-6 Hours - $ 14.00
6-7 Hours - $ 35.00*
7-24 Hours - $40.00**
*with validation rate will be reduced to $16
**with validation rate will be reduced to $20
(3,382 Views)
What trouble are you having?  Ask a specific question.  Post your VI so we can see what you've done and where you are stuck.
I would recommend you learn more about LabVIEW from here. How to Learn LV
(3,376 Views)
I dont know how to start this problem other that use case structure and for loops.
(3,364 Views)
It'll be hard to provide help with that.  What's your input look like?
(3,332 Views)
2 Datetime controls, start- and stoptime
1 subtract
2 array constants, one with (upper) time limits, one with corresponding cost.
1 Threshold array
1 Index array.
1 Cost output.
Profit.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,294 Views)
I'd have suggested the same method (perhaps without the timestamps and subtract, and just a Numeric Control, but that depends on the input format of course), but I didn't because I figured that Threshold 1D Array can be a bit tricky.
In this case, I think you'd also want a "Round towards +Inf" with the way you described your arrays?
I managed to get it to work with the lower bounds of the price brackets and a Round toward -Inf node, but maybe up is better...
My only point is that Threshold can be a bit difficult. Although you'd probably still need to Threshold 1D Array to build a bunch of cases in a case structure... (unless your input is integer minutes?)
GCentral
(3,273 Views)
