How to apply bilateral filter over a 2d matrix image
I have got ans(just image) for this bilateral filter but confused with Call Library Function Node
How to attempt a bilateral filter over a 2d Matrix image
Message 1 of 26
(5,548 Views)
I want to apply bilateral filter to this image
I have code for matlab how to convert it in labview
Img=360x360
patchVar = std2(img)^2;
DoS = 2*patchVar;
J = imbilatfilt(I,DoS);
imshow(J)
Message 2 of 26
(5,540 Views)
No need for double posts, keep things in one place...
Message 3 of 26
(5,511 Views)
I have a python code also for this without any  builtin function
But unable to convert this for Labview
import numpy as np
import cv2
import sys
import math
def distance(x, y, i, j):
    return np.sqrt((x-i)**2 + (y-j)**2)
def gaussian(x, sigma):
    return (1.0 / (2 * math.pi * (sigma ** 2))) * math.exp(- (x ** 2) / (2 * sigma ** 2))
def apply_bilateral_filter(source, filtered_image, x, y, diameter, sigma_i, sigma_s):
    hl = diameter/2
    i_filtered = 0
    Wp = 0
    i = 0
    while i < diameter:
        j = 0
        while j < diameter:
            neighbour_x = x - (hl - i)
            neighbour_y = y - (hl - j)
            if neighbour_x >= len(source):
                neighbour_x -= len(source)
            if neighbour_y >= len(source[0]):
                neighbour_y -= len(source[0])
            gi = gaussian(source[neighbour_x][neighbour_y] - source[x][y], sigma_i)
            gs = gaussian(distance(neighbour_x, neighbour_y, x, y), sigma_s)
            w = gi * gs
            i_filtered += source[neighbour_x][neighbour_y] * w
            Wp += w
            j += 1
        i += 1
    i_filtered = i_filtered / Wp
    filtered_image[x][y] = int(round(i_filtered))
def bilateral_filter_own(source, filter_diameter, sigma_i, sigma_s):
    filtered_image = np.zeros(source.shape)
    i = 0
    while i < len(source):
        j = 0
        while j < len(source[0]):
            apply_bilateral_filter(source, filtered_image, i, j, filter_diameter, sigma_i, sigma_s)
            j += 1
        i += 1
    return filtered_image
if __name__ == "__main__":
    src=cv2.imread(str(sys.argv[1]), 0)
    filtered_image_own = bilateral_filter_own(src, 5, 12.0, 16.0)
    cv2.imwrite("filtered_image_own.png", filtered_image_own)
Message 4 of 26
(5,499 Views)
Accepted by gptshubham595
finally solved this
Thank you @Raven, @GerdW, and all community members
many times I was unclear with my posts coz I was breaking parts of this in a simpler form, I failed in some attempts to explain clearly, after learning from various other docs and with community help! Successfully got this!
Thank You!
will improve me! 😇
Message 5 of 26
(5,468 Views)
Hi gpt,
@gptshubham595 wrote:
finally solved this
Well, are you sure you need those two innermost loops?
Why are there so many coercion dots, especially on your own subVIs?
Still need to cleanup the block diagram! (Like the hidden wire from outermost loop "i" terminal to tunnel of next loop…)
Use better labels for controls/indicators. Using "integer" for an U32 indicator seems senseless…
Message 6 of 26
(5,463 Views)
There are a total of 4 loops in python so yes
I am using double+int so I think it is showing red coercion dots
Sure, will try to clean up and make it look better in term of displaying some hidden wires
For labels it was a test for some reason so text not mattered much as of now renamed it btw!
Thank You!
Message 7 of 26
(5,448 Views)
Can you attach the code for it?
Rahul
Message 8 of 26
(5,427 Views)
Message 9 of 26
(5,372 Views)
Hey Rahul you can use this directly to do this using above python code and python integration toolbox via Enthought
Message 10 of 26
(5,352 Views)
