How to append the items form listbox to string array
hi,
I need help related to listbox
1. Currently I am able to select item and put into array string
Prob is
ex.
When i select item 1 then Item 1 will be create on arrayString but when I select item 2 and item 3 then arrary string displays item 2 and item 3 and item 1 will be deleted.
So please let me know how to add, append and delet from listbox to array string.
2. How to popup the listbox and allow user to add, delet or append the items in the listbox and transfer to array string
I have atatched my code. Please help me.
thanks,
chethan
Message 1 of 11
(5,603 Views)
@Mandya wrote:
hi,
Prob is
ex.
A picture doesn't really help here.  You need to post the actual VI.
If you want to append, then you need some way of retrieving what data is already in there.  A shift register or a local variable should work well for that.
Message 2 of 11
(5,591 Views)
listbox has already have 10 items (strings), when i click on item the corresonding item should be selected and stored in array, my prob is when I try to add second  item after adding first item the arary delets the first item and stores the second item...
I need solution in such a way that array has to allow to append , add or delete the item which is selected from the list box....
Message 3 of 11
(5,568 Views)
Yes, I am well aware of what your requirements are.  Now show me what you have done with actual code.  We are not here to do your work for you.  We will help you along.  But just repeating your requirements doesn't help anybody.
Message 4 of 11
(5,557 Views)
I can't disclose entire code...the above req is small part of it.......
currenlty i am able to add but not able to append or delete
Message 5 of 11
(5,550 Views)
Take a look at this code, it allows you to maintain the output array (listbox2) by moving items back and forth between listbox and listbox2. Does this help you in anyway? If not, what additional functionality do you need?
Charles Chickering
Architecture is art with rules.
...and the rules are more like guidelines
Message 6 of 11
(5,534 Views)
I have labview 2010 and not able to open this file
Message 7 of 11
(5,529 Views)
Accepted by topic author Mandya
Sorry, try this:
Charles Chickering
Message 8 of 11
(5,525 Views)
thank you very much...its working
Message 9 of 11
(5,512 Views)
hi,
I have attached the VI and fails to move items from listbox to another listbox.....could you help me...
thanks,
chethan
Message 10 of 11
(5,462 Views)
