How to add new data to existing data in excel file?
I would like to save the data (Name, Age, BPM) which are manually keyed in during each run to excel. My data gets saved after the first run, however it would all get erased and only new data remains in the subsequent run. Please tell me what to do, I have attached my VI inside.
(3,773 Views)
Accepted by whyywhyy
You really write simple text (csv) file, not excel. when you write header, "append to file" terminal unused and system creates new file. You can check file for existing. If file exists, you can append date, another case create file and header before
(3,744 Views)
Never mind, the post above answers it.
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
(3,743 Views)
I'd use Check if File or Folder exist instead of Get File Info.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,737 Views)
Thanks a lot! (: It works! Exported to text file instead of excel
(3,698 Views)
