How to add comment string and line feed while writing configuration file?
I had trouble modifying the configuration file. My program can read and write configuration file. But the configuration file is not what I want.
Instead It shows clump of strings with no clear of grouping by statements.  I wanted to add newline under each [statement] and  comment to top of the string, I had a hard time modifying the file using string and file I/O functions. Sometimes the string output and file outout look different.
Written file:
[statement1]
blah
blah
blah
[statement2]
blah
blah
blah
[statement3]
blah
blah
blah
Modified File:
Comment blah blah blah...
[statement1]
blah
blah
blah
[statement2]
blah
blah
blah
[statement3]
blah
blah
blah
Any solutions?
Clement
(9,537 Views)
Hi astroboy,
some questions:
Which LV version do you use?
Which file functions do you use?
Do you use the config file functions (aka ini-files)?
Can you attach your vi here in the forum?
(9,533 Views)
Hi GerdW.
Thanks.
I managed to figure out. String and file IO functions are really knottly.
If u wish, u may have my codes  and give your comments.
Here's attached. These files are in version 7.1
rewrite_config.vi is sub-vi for write_config.vi.
so run write_config.vi.
Thanks Pal.
Clement
(9,529 Views)
Hi astroboy,
your vis look quite ok Smiley Happy
I just made comments on what I would prefer...
(9,524 Views)
Clement,
One approach I have taken to put comments into a config file is to create a Section called [Notes] (or some other term if "Notes" happens to be a valid section of keyname). I restrict each note to be a single line (no end of line characters permitted) and define the keys as Note0=, Note1=,... so that the Notes can be read or written like elements of a string array.
[Notes]
Note0=Put first note here.
Note1=Second note.
[Real section]
realKey=
Lynn
(9,516 Views)
Begin and end each comment line with "\\" characters.  Extra carriage return\line feed characters are allowed (to improve readability).  I have only tried this on Windows XP so I don't know if it will work on other platforms.  Also, I am creating my configuration files by hand in a text editor (rather than generating them programmatically through LabVIEW).  However, I am reading in the contents of the configuration files programmatically through LabVIEW.
Here is an example configuration file:
[Button1]
Text=Production Testing
Privileges=Operator,Technician,Admin
VI Path=C:\\C4Test\\Strider\\software\\labview\\Production Testing.vi
[Button2]
Text=Advanced Testing
Privileges=Technician,Admin
VI Path=C:\\C4Test\\Strider\\software\\labview\\Advanced Testing.vi
[Button3]
Text=Maintenance
VI Path=C:\\C4Test\\Strider\\software\\labview\\Maintenance.vi
[Button4]
Text=Updates
VI Path=C:\\C4Test\\Strider\\software\\labview\\Updates.vi
[Auxiliary1]
Text=Documents
VI Path=C:\\C4Test\\Strider\\software\\labview\\Documents.vi
[Auxiliary2]
Text=Home
VI Path=C:\\C4Test\\Strider\\software\\labview\\Home.vi
\\In this configuration file, square brackets enclose each section name. Every section name must be unique.\\
\\Sections contain key/value pairs separated by an equal sign. Within each section, every key name must be unique.\\
\\The key name represents a configuration preference and the value name represents the setting for that preference.\\
(9,168 Views)
