How to add a Property Node with 'Disabled(U8)
@Kyle97330 wrote:
4. Press Control-Shift-B.
Kyle97330_1-1607362142582.png..
Also note that for a dropped property node or method, you can change the class with QD , CTRL+B. This makes it easy to switch from Application to VI...
Also works for class specifier constants.
Sometimes it pays to read the manual 😊.
Message 11 of 13
(745 Views)
< risking going off topic >
I might have a use for that
@LittleBigPig wrote:
Curse fitting vi.  Often my curses are crude and not easy to express in public.   I have tried cursing in French but, I need help there too! (Pardon my French)  Futau moi!
"Should be" isn't "Is" -Jay
Message 12 of 13
(739 Views)
Dutch curses will stretch the fitting scales. They should be included during beta testing.
Take any 'normal' curse from any language, and put a (serious) disease before it. You'll have a pretty normal Dutch curse if you used an extinct disease and an offensive one if you use an existing disease. Not proud of it. Not sure where that came from... See this instructive blog.
Message 13 of 13
(732 Views)
