How to access only the third dimension within a 3d array?
It looks like a good start.
Remember what I said about For Loops.  The iteration counter begins at 0.  But your loops start at either 1 (for n loop) or 2 (for i and j loops).  So you need to add 1 or 2 to your iteration value before you do anything else.
From here on, you'll just have to add more code to account for the other parts of your equation.
Message 21 of 25
(634 Views)
thank you, i completed that section. and now need to set the boundary conditions because as i run the code i encounter the error that labvoew has run out of memory, so again using index array and replace array subset in the first loop i have to carry out this code. how could i equate them?
u(1,:,n+1) = u(2,:,n+1) ;
u(length(x),:,n+1) = u(ni-1,:,n+1) ;
u(:,1,n+1) = -u(:,2,n+1) ;
u(:,length(y),n+1) = -u(:,nj-1,n+1) ;
kindest Regards,
Message 22 of 25
(633 Views)
I don't know what you mean by "set the boundary conditions".
Message 23 of 25
(630 Views)
i want to set a maximum limit for the arrays when they execute, as my code stand it doenst run because there isnt enough memory in labview.
Message 24 of 25
(627 Views)
See the boundary condition question in this thread.
Lynn
Message 25 of 25
(621 Views)
