How to access common global variable between different Packed Project Library
Accepted by topic author DanielDu
DanielDu wrote:
     As an alternative option, I would like to make sure Test Task.lvlibp calls the version from DataProcess.lvlibp. But I can not imagin how to implement it.
The simplest solution is multiple projects.  You have a project for DataProcess.lvlib to build DataProcess.lvlibp.  You then have DataProcess.lvlibp in your main project where Test Task is used.
GCentral
Message 11 of 12
(1,049 Views)
    Thanks for your new idea !
    I am not very clear about "how to refer to the queue by name in each PPL?"
Message 12 of 12
(1,049 Views)
