How to Convert SPI Data Correctly?
I have an ADC of ADS1256, I try to use Myrio to read the data via SPI, but I get stuck when converting the data~ Can you help how to get the correct data?(ADS1256datasheet )
I gave a set of ARDUINO's code which works fine, and I tried to emulate his conversion without success.
I'm trying to put this code on labview now, can anyone help me?
Spoiler
adc_val[i] = SPI.transfer(0);
adc_val[i] <<= 8; //shift to left
adc_val[i] |= SPI.transfer(0);
adc_val[i] <<= 8;
for (i=0; i <= 2; i++){ // Single ended Measurements
if(adc_val[i] > 0x7fffff){ //if MSB == 1
adc_val[i] = adc_val[i]-16777216; //do 2's complement
 Where am I doing wrong?
Note, FORLOOP is used to read multiple values ​​consecutively.
Message 1 of 8
(5,549 Views)
Hi koukileo,
adc_val[i] <<= 8;
What about this one:
Message 2 of 8
(5,535 Views)
Accepted by topic author koukileo
Thanks for your reply, I finally understand my problem, the ADC is 24bit data, so I want to divide it into three sections with 8bit. The code is as follows~
Code part from this article: SPI on myRIO with synchronous 8 channel ADC
Message 3 of 8
(5,511 Views)
Your code is great too~ Made me understand new ways.
Message 4 of 8
(5,509 Views)
Hi koukileo,
@koukileo wrote:
Thanks for your reply, I finally understand my problem, the ADC is 24bit data, so I want to divide it into three sections with 8bit. The code is as follows…
Quite convoluted!
Whenever you start to copy&paste the same code several times you should think about using a loop to call that code repeatedly! (And when you combine this with LabVIEW autoindexing feature it becomes really easy…)
Message 5 of 8
(5,498 Views)
Thanks for your advice~ I forgot to have this method. Thank you very much~
Message 6 of 8
(5,472 Views)
Hi koukileo,
Why use a loop (or duplicated code) at all when you only need the result of the first iteration?
Message 7 of 8
(5,443 Views)
What you can see in the picture is to demonstrate the use.
I actually have a 3-axis accelerometer, so I end up needing 3 DATA~
Best regards
Message 8 of 8
(5,430 Views)
