How switch boolean by puls.
Please for help>
I need boolean switch :
One puls in one input will switch on and other puls in second input will switch off
Thanks.
(4,799 Views)
Your English is not quite good enough to explain your problem.  Do you want a boolean switch to choose which input to use?  Like this?
Message Edited by tbob on 12-19-2005 01:26 PM
- tbob
Inventor of the WORM Global
(4,792 Views)
The attached VI shows two ways to do it. Which one you choose to use will depend on whether your set/reset inputs are coming from user events (the upper example) or some other internally-generated logic (the lower example). In both cases the outer-most While loop is just there for the sake of the demonstration.
Message Edited by Warren Massey on 12-19-2005 01:21 PM
(4,785 Views)
Hi.
I would like to thank you very much. It is very simple and it run as I need. Shift register is usefully.
With regards JaraSmiley Happy
(4,762 Views)
