Sorting-Order at File->open
when I cklick in the menue on File + Open then then i can select a directory/file to open. The problem is thatr
the order is always "by date". The newest file is the first. I want to have it normal sorted after alphabet.
In other windows-xp programs its normla (word, excel...)
Is this a labview-property somewhere (hmm, its also wrong in teststand)?
Thanks for your help
(2,815 Views)
Hello NewOne,
if you are using Windows, then the standard file dialog uses windows settings. So if you set somewhere (folder options ?) the sorting order to date, then the file dialog sorts by date. I don't think there is a LabView option to change this  behaviour.
(2,810 Views)
