How do you change multiple plot properties programatically?
How would you programatically change the color and line size of different plots? I know you create a property node but when I do that I don't seem to be able to specify which plot I want to change.
For example: plot 1 is green w/ dotted line, plot 2 is red with solid line.
I want to programatically change say plot 1 to a blue solid line and plot 2 to a yellow line.
There is a "plot name" property but no matter what name I specify it changes all the plots.
(3,641 Views)
BUMP
(3,633 Views)
First, you have to use the "Active plot" property, as in the attached example...
CC
Chilly Charly    (aka CC)
(3,631 Views)
Thank You - That did the trick.
(3,623 Views)
