How can i control a toggle switch manually and automatically?
I want to know how can it be possible to automatically flip a toggle switch when data comes in.
I know this can be done manually, but what about automatically, without any user?
(5,560 Views)
Attached, is a cluster of logic switches that i have that i want to toggle manually and automatically.
Also there are 3 single switches that i also want to do the same thing.
(5,555 Views)
For the individuals, in the block diagram, right click on one, select create/property node, then select value and change to write. Attached is a simple example that flip flops boolean 1 switch using a shift resgister and timed loop (just a quick means of showing hot to change, but not the only means). For the clustered ones, you may have to undbundle them, change value, then rebundle.
(5,550 Views)
You can use local variables and write to them to programatically control the boolean switches. For the cluster, you can again write to a local variable, but you have to use bundle to choose which switch to control. See attached vi.
- tbob
Inventor of the WORM Global
(5,548 Views)
thanks for the insight.
How can i make the following switches toggle? I want them to toggle individually.
That is:
001 hex
002
004
008
Or: switch 1 on, the rest off
switch 2 on, the rest off,
switch 3 on, the rest off,
switch 9 on, rest off.
I tried to do this with a for-loop and no end result.
I know one can do this with a sequence, but it will then be a sequence of 9. Too much!
See attached file.
Thanks In Advance!
Fred
(5,541 Views)
Here's a kwik kludge (I'm doing visual basic programmind at the same time; can't focus on LV!), I'm sure tbob or dennis have something more elegant.
Hope it puts you on track
(5,534 Views)
I would suggest to place the booleans into a 2D array, less things to shuffle.
See attached example (LabVIEW 7.0)
(5,530 Views)
