How do i add a graph behind my waveform .
How do i make a graph behind my waveform .
Example.
Message 1 of 19
(3,728 Views)
You have to plot those two parameters in the same plot. You can use the 2D array format of waveform chart to achieve this.
Message 2 of 19
(3,725 Views)
I don't get it .
Message 3 of 19
(3,723 Views)
You can build the data and pass it to a single chart. Check the attached example and also go thorugh the LabVIEW basic materials.
Message 4 of 19
(3,708 Views)
i can't view it . mine is labview 7.1
Message 5 of 19
(3,704 Views)
Just check the attached picture. In the chart incase if you are not getting the 2 plots you may need to transpose the array. for getting two plots in the same chart click the y scale and duplicate it and then try the attached example.
Note: The attached example is just for showing multiple plots in a single chart.
good luck.
Message 6 of 19
(3,699 Views)
I understand about the multiple plots . but as you can see the picture . one is in wave form , one is square form .
Message 7 of 19
(3,693 Views)
Yes both has data right so you can plot it.
Message 8 of 19
(3,688 Views)
Can u help me take a look . i don't get it still . thanks . been trying for the whole day .
Message 9 of 19
(3,674 Views)
I see you are plotting the same data again with different colors. But as per your requirement you need to have different plots for different data. I don't understand what you are trying to achieve in the vi you attached.
Message 10 of 19
(3,670 Views)
