05-28-2012 04:49 AM
This is what i'm trying to achieve .
05-29-2012 08:26 PM
anyone out there to help ? because i really don't get it .
05-30-2012 01:49 PM
What don't you get? Your latest attachment shows you are plotting two waveforms simultaneously.
05-30-2012 02:33 PM
Are you just trying to get grid marks on your chart? If so just right click your chart and select properties. Select the scales tab>>y axies and click a color (T) on grid styles and colors major grid. The T designates transparent so choose white.
Hope this helps
05-30-2012 02:58 PM
I've seen that SupervisorsExample before. It's a homework assignment and the task is to make a VI work in a similar manner. The op's code is the VI called melvin. It seems there are several problems - including not having another plot.
06-13-2012 10:49 PM
Now i'm kind of stuck i still don't know how to make my temperature plot like this green line
06-13-2012 11:02 PM
06-14-2012 04:32 AM
What im trying to ask for is . for my temp plot . i need to make like curve shape similar to the supervisor example but i cannot use everything from there . but i dont know how .
06-14-2012 11:03 AM
Well, it looks like the plot interpolation is actually correct. The basic problem is the way you are generating the temperature value.
