How do I use multiple children classes?
OK, I'm lost.
In the image from a shipping example with LabVIEW, I can see how the circled example works. What I want to be able to do is use more than 1 child, in the same way. Do I have to replicate the code for the other child, or can I somehow have more than 1 child use the same wire?
(2,928 Views)
Accepted by topic author elrathia
Use an array where each element in the array is an instance of the child you require.
Invoke your methods inside an auto-indexed For loop.
Ben
(2,924 Views)
Thanks Ben.
That worked, but showed me that I was following the wrong course. The methods in the loop only allow work on the parent class data. I can't access the child class data at all. So I'll have to figure some other way to do what I want.
(2,907 Views)
Just remember, as a class data is in private scope in LVOOP, only the class it self can access it's own data, no matter if it is a child or parent.
And a child class will NOT inherit the parents data.
(2,898 Views)
