How do I set app revision in LV Pro 6.1
Is there a way to embed revision information from the built-in SCC into a compiled application? I'd prefer to label all VIs with one label and then have that label in the application revision.
If I cannot do it automatically, how do I manually set the revision information for a stand-alone application? When I bring up the stand-alone application and choose VI properties I get revision 0.
I'm using Labview 6.1 Professional
Bob
(2,719 Views)
I do not think you can do that off the shelf.
Check out Jim Kring postings for a link to the open source code project.
I believe they have a method for doing what you want.
Ben
(2,719 Views)
http://ogab.sourceforge.net
This link may get you there.
(2,719 Views)
