How do I output multiple loops with the same chart?
I have a case statement which selects an appropriate binary file decoder. The decoder works inside of a while loop. Is there a way that I can use the same two output elements (a numeric output that displays the current sample and a chart that displays the signal) which exist inside the loop with all of the decoders? Or am I going about this entirely wrong? I am new at this and any advice would be appreciated. Thanks.
(2,705 Views)
If I understand you correctly you want to update the same indicators from different cases.
If the indicators will be update in every case then move the indicators outside the case, and wire from within each of the cases to the indicator.
If the updates to the indicators only happen in specific cases, you can "right-click" on the indicator (from diagram) and select "create local". Right-click on th enew local and set it as "write". Move this to the other case where you want to do the update, and wire it up just the way you did the terminal.
Repeat as many times as you need.
Ben
(2,705 Views)
