How do I remove this break point?
I have a set of VI's from Elgar/Sorenson for controlling an old DC power source.
One of the main VI's has a breakpoint set in it so it always pauses when it gets to this VI.
This is the read/write VI that is burried inside every VI for this device so it makes the program pause a lot.
When I open the block diagram there is a red border around it, is this some kind of "always pause" setting?
How do I unset this?
=== Engineer Ambiguously ===
(5,244 Views)
Accepted by topic author RTSLVU
You can go to the View -> Breakpoint Manager menu and then remove the breakpoint and save the VI.
Ben64
(5,238 Views)
Also Edit>>Remove breakpoints from heirarchy
last but not least select the breakpoint tool from the tools palatte (shift+Rightclick to bring up the tools palatte) select the BP tool and click anywhere on the root of that BD
"Should be" isn't "Is" -Jay
(5,232 Views)
I tried using the Breakpoint Tool on the block diagram and it did not work, that is why I asked.
(5,227 Views)
That should work just fine too. Select the breakpoint tool and click on the toplevel diagram, outside of any structures.
The VI can be in run mode or edit mode.
(5,205 Views)
Breakpoint on block diagram is now removable by Edit->Undo breakpoint, it doesn't show up in the breakpoint manager. You can also use short-cut ctrl+z to remove breakpoint on diagram.
(5,037 Views)
