06-13-2007 10:43 AM
06-13-2007 10:55 AM - edited 06-13-2007 10:55 AM
Message Edited by daveTW on 06-13-2007 05:56 PM
06-13-2007 11:02 AM
06-13-2007 11:05 AM - edited 06-13-2007 11:05 AM
Message Edité par JB le 06-13-2007 06:05 PM
06-13-2007 01:10 PM
@JB wrote:
One time in picture and one time in text... daveTW sent his answer while I was typing mine !
06-13-2007 02:04 PM
So it looks like we have a virtual tie.
So now for the tie-breaking question (are you ready?)
When using a waveform datatype with charts and graphs, what property should you check if the previous suggestion does not work?
Ben
06-14-2007 02:07 AM - edited 06-14-2007 02:07 AM
P.S. @ J.B. I used the Code Capture Tool from the Starware Thread, this made me so fast. If I could do, I would give it five stars each time I use it.
Btw. would it be possible to programmatically give ratings with LV? Here it should be used. Thanks again to tst & the others
Message Edited by daveTW on 06-14-2007 09:13 AM
06-14-2007 06:05 AM - edited 06-14-2007 06:05 AM
Ah but if your waveform had attributes...
then the "ignore attributes" option would prevent the graph/chart from using the names included as one of the WF's attributes.
I believe if you use DAQmx channels, these come automatically.
Ben
PS Yes you can give stars with LV.
Message Edited by Ben on 06-14-2007 06:06 AM
06-14-2007 06:53 AM
09-26-2008 03:24 PM
you guys are awesome!
thanks for bringng this up.
