How do I position a window dynamically?
I want my customized "Get Serial Number" vi to be in one of two positions on the screen.  How can I get the system screen metrics so I can determine the (top,left) coordinates of the vi window, and set the position of the window within the vi?
Mike
(3,566 Views)
If you are using a PC, the screen size can be found using the .NET Property Node under Systems.Windows.Forms.SystemInformation.PrimaryMonitorSize
You can move the vi front panel using a property node with a reference to 'This VI'.  I have enclosed a not-too-elegant yet functional example.  Hope this helps.
-Darin
Message Edited by Darin.K on 07-16-2009 06:55 PM
(3,561 Views)
Accepted by mike_22
For those of you not tethered to PCs, a more platform-independent method for the screen size would be the Display WkSpace property, just pass an application reference to the property node and select DisplayWkSpace property.
-Darin
(3,552 Views)
Thanks to both of you.
(3,525 Views)
