How do I make a boolean indicator show 3 states instead of 2
Boolean is 2-state.  I just wish I could make it like a stop-light.
Green is "go", yellow is "danger" and red is "stop".
Any suggestions how to do this?
Message 1 of 10
(9,043 Views)
Accepted by EngrStudent
Hi EngrStudent,
Unfortunately, LabVIEW does not currently offer support for strict Boolean controls with 3-state capability. However, there are numerous workarounds of varying complexity that will allow you to implement functionality similar to a stop-light.
This thread might be a good place to start:
3-State Control w/ Colors
This problem is also documented in a number of other threads on the forums already. I would recommend a quick Google search if the above thread is unable to help you.
Duncan W.
Message 2 of 10
(9,025 Views)
There is an XControl here that is like a tristate boolean (if there is such a thing).  Haven't downloaded it to try it out but it looks nice.
aputman
Message 3 of 10
(8,998 Views)
By definition, a boolean only has two states, so it cannot be a boolean datatype.
LabVIEW has the mixed checkbox that I use occasionally.
in the more general case I would use a colorbox (that can e.g. be made to look like an LED).
... hmmm, I see that the above link already points to my similar response from 9 years ago. Nothing has changed! 😄
But there is also this idea that is worth voting for. 🙂
Message 4 of 10
(8,991 Views)
Yes, indeed!  Another vote added ...
Message 5 of 10
(8,972 Views)
Another option would be a picture ring.
Message 6 of 10
(8,969 Views)
@altenbach,
I didn't like it being a boolean with 3 states.  To be a boolean it could have any number.  A binomial is intrinsically 2-state, but boolean techniques work with multinomials.  I think a trinary indicator is more technically correct, but I couldn't be sure folks would know what I meant.
I was hoping for a built in.
Message 7 of 10
(8,938 Views)
well, there exists a "3-Zustands Feld" or "Mixed Checkbox" under
Frontpanel>Elements>System>Mixed Checkbox
http://zone.ni.com/reference/de-XX/help/371361N-0113/lvhowto/configure_mixed_checkbox
Message 8 of 10
(8,932 Views)
According to Wikipedia, " the Boolean data type is a data type, having two values (usually denoted true and false),"
So, yes, any set with two possible values can be represented by a boolean (exactly one bit!), e.g. (500, -3), (Red, green), (light, dark).
Why are you mentioning binominals?
Ternary logic is well defined, but these are not booleans and need more than one bit to represent the value. The mixed checkbox I mentioned earlier is more of a cosmetic thing, because you cannot do ternary logic with its value directly. I typically use it to represent (All, some, none) when selecting other items.
From reading your question, you simply want an indicator with a limited set of values. LabVIEW has plenty of those. Look at rings and enums. In particular you can use a picture ring indicator with three colored images (as I suggested already)  and you are already there. You can even give each state a name (e.g. red|green|Yellow). So yes, there are "built-ins" 😄
The color LED is useful for fancier UIs, e.g. when you want the color to change gradually between states.
Message 9 of 10
(8,922 Views)
I was thinking of boolean in the sense of binary adder from boolean algebra, from my digital logic class. (link)
I'm sorry for any confusion.
Message 10 of 10
(8,857 Views)
