How do I explain error in executable?
As everyone knows, there are 3 parts to the error cluster: status, code, and source. The status is the flag, the code is the error code, and the source is where Labview thinks the error occured. Normally when I am in the labview environment I can just right mouse click on the error and hit 'explain error' and a detailed error description and possible cause comes up.
However, when I create an executable i dont know how to explain the error to the user like labview does.
When an error occurs I would like to have a popup that tells the error code, source, and EXPLANATION. The code and source alone is so cryptic its rather panic inducing to the user, whether or not the error is fatal/crash-inducing. Also it would save me having to look up the error code online.
How do I get the explaination of the error code? Is there a vi that i can input an error code and get the explanation string?
There is probably something simple I am overlooking but I couldn't find the answer in my searching. Thanks in advance for your help.
[will work for kudos]
(3,849 Views)
Accepted by rex1030
Simple Error Handler and General Error Handler vis?
(3,847 Views)
Feel free to mark your reply as the solution. Smiley Wink
Ben
(3,838 Views)
While the error handlers of reply one also work in the IDE, you can also right-click on the error cluster and select 'explain error' when debugging a SubVI.
Felix
(3,835 Views)
