How do I create an artificial horizon indicator?
Hi viru,
check this link
attitude indicator
I really would like to see an attitude indicator! 😄
Message 11 of 14
(2,467 Views)
if you could not find what you want in Aircraft bank angle example
you have to use pictures function to make it  or use one cluster and try to change some indicator inside it to achieve this
and check
robotics toolkit attitude indicator
undefined
also check this link if you do not check before
https://decibel.ni.com/content/docs/DOC-17581
Message 12 of 14
(2,459 Views)
Did you ever manage to replicate this from Mission Planner?
Message 13 of 14
(1,603 Views)
A decent Attitude or Pitch Roll sensor is still something that is sorely missing in LabVIEW I feel. The Robotics Module used to have one. As others have shown it is possible to create one using pictures too, but there is a lot of code to get a decent looking one, and you have to have the Full Development Suite whereas I only have the Base version. I have modified Polar plots for Roll, but it doesn't really translate well for pitch. Has anyone else found a simple solution recently?
Message 14 of 14
(1,185 Views)
