Artificial horizon
I am trying to program an artificial horizon to be used in an experimental aircraft. How do I do this???? Are there any samples or references to this subject on the net or other places???
Sjur
Message 1 of 14
(4,649 Views)
Someone else suggested this in another post.
http://www.globalmajic.com
Philip
Message 2 of 14
(4,647 Views)
I'm no pilot, but a crude way of doing this is to use a LabView gauge indicator with multiple needles. Do the math to make the needles always point in opposite directions.
Run the attached LabView 6.1 example and play with the stick.
Message 3 of 14
(4,651 Views)
Hi, I am also trying to find an artificial horizon and have also posted on a few forums. Have you had any success and if so could I have the instrument?
thanks
Andrew
Message 4 of 14
(4,516 Views)
This thread
http://forums.ni.com/ni/board/message?board.id=BreakPoint&message.id=14&jump=true
shows you how to use the Picture control.
Altenbach "rotate image" example can be used as a start.
If this work for you, please post your final solution and I will link your solution into that collection.
Ben
Message 5 of 14
(4,495 Views)
Very nice..
Thanks Ben!
Message 6 of 14
(4,488 Views)
A search for "horizon" in this forum gives this most interesting example, still waiting for a bunch of 5 stars...
Correction :
Andrew, since you already found this example, can you explain in more details what you were searching for ?
Correction 2 :
Just in case you had some difficulties opening the Macintosh example file (I forgot the .vi extension), here is a window version
Message Edité par chilly charly le 03-27-2006 05:20 PM
Chilly Charly    (aka CC)
         E-List Master - Kudos glutton - Press the yellow button on the left...
Message 7 of 14
(4,474 Views)
Thanks CC,
I was wondering wher that idea came from!
Ben
Message 8 of 14
(4,463 Views)
CC,
Yes...  you deserve multiple *****.
we'll have to work on that...
Unfortunately, multiple 5-star assignments do not increase the overall count.. only improves avg.  (yes.. you mentionned that before) 😉
Message Edited by JoeLabView on 03-27-2006 11:28 AM
Message 9 of 14
(4,458 Views)
JoeLabView a écrit: "...Unfortunately, multiple 5-star assignments do not increase the overall count.. only improves avg.  (yes.. you mentionned that before)"
Wrong ! That's the reverse !
JLV, I can see that you didn't improve your attention since the time when you sent crawling worms to the North of France, while I'm living in the South (see the post date...)  😛 😄  Anyway, merci pour les étoiles !
Message 10 of 14
(4,445 Views)
