From 11:00 PM CST Friday, Apr 11th - 1:30 PM CST Saturday, Apr 12th, ni.com will undergo system upgrades that may result in temporary service interruption.
03-18-2023 01:25 AM
"Test single stage.vi" calls single Task.vi of Zaber library using Start Async Call Node.
Profile performance and memory dialog shows:
- 5 (!!!) Task.vi and 4 looks as Task.vi:Instance:***
- 5 (!!!) "Test single stave.vi": one as "Test single stave.vi", two as "Test single stave.vi:Instance:***" and two "[Test single stave.vi]"
Why?
03-18-2023 12:47 PM
03-18-2023 12:49 PM
Task.vi is reentrant VI.
03-18-2023 12:53 PM
Ohh ... Test single stage. VI is also reentrant vi. It is top level vi and there isn't reason to make it as reentrant. I will place new Profile dialog later.
03-18-2023 07:30 PM
Test signal stage.vi is non-reentrant. No changes/
03-19-2023 12:33 PM
What's the question?
03-19-2023 10:02 PM
Why are there 5 lines "Test single stage.vi" and "Task.vi" instead of one line?
03-20-2023 02:05 AM
Hi Vasilich,
Now there's time to attach some code so we can examine the problem.
(It's quite hard to analyze from looking at some images of the profiling dialog…)
03-20-2023 05:18 AM
I'm assuming Task is Preallocated reentrant. If so, it'll create an instance for each placed in the code (or a few in a parallell loop). (qualified guess)
03-20-2023 06:01 AM - edited 03-20-2023 06:02 AM
Your profile window clearly proves otherwise! It may not be the VI itself set to be reentrant but the way you launch it in your program.
As others said: It's time to attach some code. Debugging images is always a pitta.
