How do I convert a text file to a time signal
I'm confused on how to do this. I can get the text file to read correctly into a an array (orange wires) but how can I get it to become a time signal (thick brown wire)? I have all the data points and I know the sample frequency is 2 samples per second. Any help at all would be great.
(4,341 Views)
Accepted by canyon
Do you mean a waveform? If so, try a 'build waveform', with 2 seconds as dt and a suitable time for t0.
Or maybe a timestamp? If so, you could try 'To time stamp'.
From your description, I am guessing you are after the waveform option?
(4,336 Views)
Wow thanks a ton! Sorry for the really basic questions, I just started with this basic project two days ago. One other quick question I have is that that the t0 input looks like it's a thick brown wire as well. I want to start it at zero how should I do that?
Thanks again!
(4,331 Views)
Glad to be of service!
For the second question, right click on the t0 input and select create constant or create control. This will create a timestamp that you can edit to a time/date of your choosing.
(4,324 Views)
You mentioned that you are new to LabVIEW. National Instruments has a large number of resources to learn and explore the language capabilities and features. I recommend starting here:
LabVIEW Training: Learn LabVIEW in Three or Six Hours
http://zone.ni.com/devzone/cda/tut/p/id/5247
Beyond that, the Developer zone has a huge supply of example code and webcasts etc that are really useful. Happy coding!
- Regards,
Beutlich
(4,283 Views)
