04-25-2013 11:38 AM
How can I use simulation loop on a compactRIO 9014?
HI
I’m new and I hope that somebody can help me. my problem is this:
i wanna use simulation loop of module control design & simulation on a FPGA CompactRIO 9014 but I don’t know how to timing of target FPGA 40 MHz with the parameters of configure simulation parameters.
When I try to compile my program I get this error…
Initializing...
Calculating dependencies...
Checking items for conflicts. This operation could take a while...
Preparing items for download. This operation could take a while...
Deploying vi de prueba.vi:Instance:1
Deploying XDNodeRunTimeDep.lvlib
Deploying prueba.lvproj
Deploying RIO-LUIS-CORPORATION(successfully deployed target settings)
Deploying NILVSim_GetBlockNameAndCallChain Core.vi
Failed to download NILVSim_GetBlockNameAndCallChain Core.vi
LabVIEW: Failed to load shared library NILVSim.*:SIM_GetBlockNameAndCallChain:C on RT target device.
Deploying RIO-LUIS-CORPORATION Container
Deployment completed with errors
This is my configuration
I use labview 8.6
compactRIO 9014 4MHz
thank you for your help
04-25-2013 01:04 PM
Hey zeuszero,
This isn't exactly my area of expertise, but since no one had replied to you yet I just wanted to share my initial thought. Sometimes I run into problems with Real-Time hardware when I don't have the proper support installed, then get similar errors like you. So, can you verify that you have installed the Control Design & Sim support on the RIO controller? You software window will look different than this one if you are using LV 8.6, but I think you'll still have a similar entry. (Go to MAX, find your RIO in Remote Devices, and right-click "Software" to Add/Remove Software.)
Anyway, that's just my first guess. I'll post back if I can think of anything else. Hope that helps.
Cheers,
04-26-2013 12:31 PM
i did it
i don't know what happened, but when i uninstalled the module real time my program worked well
thanks for your reply
