How can add other software to my design
Dear Engineer
I need to add a other software for my design of labview .
I want this other software to enforceable in the my design of labview .
How i can to add a other software for my design of labview .
please help me about this problem .
thanks & best regards
(3,625 Views)
Accepted by topic author ehsanbehroozy@yahoo.com
Hi ehsanbehr...,
can you explain in more detail what you mean? Which other software do you want to use?
Mike
(3,612 Views)
Why LabVIEW alone not enough for your design of labview?
Andrey.
(3,600 Views)
If the other software has ActiveX components, then it is relatively simple to manipulate through LabVIEW.
_____________________________
- Cheers, Ed
(3,584 Views)
thank you very much for help me .
How i can to analyse microphone input of computer in the labview .
I want analyse microphone signal in the labview .
Do you have sample of labview for this problem.
best regards
(3,561 Views)
To analyze anything in LabVIEW you have to be able to access the signal through some sort of DAQ board. Once you have the signal going to a board then you have to have the right driver (packaged code) to be able for LabVIEW to communicate with that device. There are a lot of supported drivers at ni.com/idnet or you can create your own. Check out this site for how LabVIEW interacts with Audio. This other site  has information on using your local sound card with your microphone or speaker input/output to interact with LabVIEW. Hopefully this will get you started in the right direction. Make sure and only add the answered tag to your post only if your question was truly answered and Kudos are always appreciated. Cheers!!
(3,552 Views)
