LabVIEW 8.6 fpsane.cpp 434
I had an internal error when I started working on updating a medium sized application (roughly 500 vi) from Labview 8.5.1 to LabVIEW 8.6. I am trying to use the classes and objects to reorganize my application to get a eaiser maintained solution. I had about 8 classes with controls that were strict type def'd before. I allowed the strict type defs to carry forward into defining the class object. I'm a rank beginner with the OOB stuff so I'm not sure if I broke something by doing something crazy or unnecessary.
 Here is the error printout, which I did allow the app to send it in to NI. But I haven't actually asked for help on it yet. I'm not sure that it's a killer bug.
#Date: Thu, Feb 05, 2009 2:53:35 PM
#OSName: Windows NT
#OSVers: 5.1
#AppName: LabVIEW
#Version: 8.6
#AppKind: FDS
#AppModDate: 06/26/2008 01:25 GMT
Insane object at BDHP+C77BB9C, UID 1089, in "NI_Gmath.lvlib:Matrix left divisionMM_general_direct.vi": {flags } (0x1000): Call Library Function Node (NODE)
c:\builds\penguin\labview\branches\Saturn\dev\source\panel\fpsane.cpp(434) : DWarn: Insanities(0x00001000) exist in ReportInsanities, 'NI_Gmath.lvlib:Matrix left divisionMM_general_direct.vi'
$Id: //labview/branches/Saturn/dev/source/panel/fpsane.cpp#10 $
0x00F3566A - LabVIEW <unknown> + 0
0x00F35E28 - LabVIEW <unknown> + 0
0x005AA7BA - LabVIEW <unknown> + 0
0x005ABC4A - LabVIEW <unknown> + 0
0x005AB190 - LabVIEW <unknown> + 0
0x005AB4F5 - LabVIEW <unknown> + 0
0x005AB7D8 - LabVIEW <unknown> + 0
0x006AA3A3 - LabVIEW <unknown> + 0
0x006AA9D5 - LabVIEW <unknown> + 0
0x006AAD7B - LabVIEW <unknown> + 0
0x006AAD31 - LabVIEW <unknown> + 0
0x006AAFEA - LabVIEW <unknown> + 0
0x006AB4AA - LabVIEW <unknown> + 0
0x011CE3BA - LabVIEW <unknown> + 0
0x01225F28 - LabVIEW <unknown> + 0
0x0122D155 - LabVIEW <unknown> + 0
0x01228903 - LabVIEW <unknown> + 0
0x00B0A055 - LabVIEW <unknown> + 0
0x00AD4792 - LabVIEW <unknown> + 0
0x116F804C - <unknown> <unknown> + 0
0x09C5CB60 - <unknown> <unknown> + 0
0x00ADC260 - LabVIEW <unknown> + 0
0x0008D8EC - <unknown> <unknown> + 0
*** Dumping Bread Crumb Stack ***
#** sanity checking heap: "N:\ATEST\Automation\PAT_2.0\Working_Source\PAT_Ver2\Matrix left divisionMM_general_direct.vi"
#** sanity checking: "N:\ATEST\Automation\PAT_2.0\Working_Source\PAT_Ver2\Matrix left divisionMM_general_direct.vi"
#** compile: "N:\ATEST\Automation\PAT_2.0\Working_Source\PAT_Ver2\Matrix left divisionMM_general_direct.vi"
*** End Dump ***
0x005ABD95 - LabVIEW <unknown> + 0
*** End Dump ***
0x010088F2 - LabVIEW <unknown> + 0
0x0100CC3E - LabVIEW <unknown> + 0
0x0100D9E9 - LabVIEW <unknown> + 0
0x0100DF9B - LabVIEW <unknown> + 0
0x0100E4BB - LabVIEW <unknown> + 0
0x00D56559 - LabVIEW <unknown> + 0
0x013F61C1 - LabVIEW <unknown> + 0
0x00D54B61 - LabVIEW <unknown> + 0
0x006AA616 - LabVIEW <unknown> + 0
#** Saving: "N:\ATEST\Automation\PAT_2.0\Working_Source\PAT_Ver2\Matrix left divisionMM_general_direct.vi"
*** End Dump ***
(3,867 Views)
Looks like you have an insane object error.  Check out the following: http://digital.ni.com/public.nsf/allkb/AFA28DCC3DE89839862566B200594E8C?OpenDocument
Since the errors are DWarns (warnings), you probably don't have anything to worry about unless they keep coming up.  Usually they will be fixed automatically.  If it comes up repeatedly, let us know.
Jeremy_B
(3,838 Views)
Thanks for the reply. I had never really understood insane objects before reading the link.
(3,832 Views)
