02-10-2009 12:31 AM
Dear Engineer
I need to add a other software for my design of labview .
I want this other software to enforceable in the my design of labview .
How i can to add a other software for my design of labview .
please help me about this problem .
thanks & best regards
02-10-2009 01:44 AM
02-10-2009 02:38 AM
Why LabVIEW alone not enough for your design of labview?
Andrey.
02-10-2009 08:03 AM
02-10-2009 02:48 PM
thank you very much for help me .
How i can to analyse microphone input of computer in the labview .
I want analyse microphone signal in the labview .
Do you have sample of labview for this problem.
best regards
02-10-2009 03:07 PM
To analyze anything in LabVIEW you have to be able to access the signal through some sort of DAQ board. Once you have the signal going to a board then you have to have the right driver (packaged code) to be able for LabVIEW to communicate with that device. There are a lot of supported drivers at ni.com/idnet or you can create your own. Check out this site for how LabVIEW interacts with Audio. This other site has information on using your local sound card with your microphone or speaker input/output to interact with LabVIEW. Hopefully this will get you started in the right direction. Make sure and only add the answered tag to your post only if your question was truly answered and Kudos are always appreciated. Cheers!!
