How can I write a bit to DIO-96 card?
I´ve got a diagram-program which works with the card dio-6533. With this I can write and read a bit to the card. Now I´ve to change the card to DIO-96 and the programm doesn´t work. First it writes a signal to the one cable connector (with 50 pins)than to the ohter cable connector (with 50 pins). What can I do to make the programm correct?
Message 1 of 26
(4,495 Views)
Using Advance Digital I/O functions,Configure the port (that read/ write the bit) and perform a Port Write (you may have to use the line mask)
PS: Check you I/O assignment for the respective Port
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
Message 2 of 26
(4,495 Views)
The problem is that Labview is new for me. I´ve taken a working programm to write. It has got a DIO Port Write.vi. Do you mean this by perform a Port Write? What is a line mask. I´ve never heard it.
The ports I´ve checked, they are ok.
Message 3 of 26
(4,495 Views)
Hi, if you are using DIO Port Write.vi
there are 3 inputs to be wired: Task ID, Line Pattern and Line Mask.
Point your cursor to DIO Port Write.vi and CTRL+H, read the help context, it is self-explained.
I have got this vi created sometime in 2000, perhaps it will help you in debugging your DIO.
Someone else might be able to help as well.
( I am trying to recall :p)
ian
Ian F
依恩与LabVIEW
Message 4 of 26
(4,495 Views)
Hope this will help you to understand.
Cheers
Ian F
依恩与LabVIEW
Message 5 of 26
(4,495 Views)
I don't know what it is (maybe I'm stupid ??) but I find NI's digital
functions a monumental pain in the t*ts to work with for several reasons;
1) for simple devices such as the pci-6503 you can configure individual
channels to READ individual bits with no problem (assuming you set the
'read' VI's port width to 1)- try and configure individual channels to WRITE
individual bits and you have a problem (basically all of the other bits on
that port get set to 'zero' when you write the bit - even when you write a
value other than zero to the iteration terminal, and even with the port
width set to 1!!) in other words 'read' seems to work fine on a bit-by-bit
basis but 'write' only seems to work on a port basis
2) several of NI's card do not give you the optio
n to set the startup
condition of the digital lines - they deafult to 'high' meaning you have to
switch a 0V input to them and then invert the value to get a high reading
(when a switch makes normally you expect a 'high' signal ??)
3) you can only have bits and ports configured as read or write - even such
'low end' board such as Arcom's PCIB-40 allows you to set a bit value and
then read it back!!!
Errrmm ... starting to run out or complaints here (well it is nearly 1:00 AM
on Saturday morning 🙂
If anyone can point out something that I'm doing very wrong here then I'd
love to hear, otherwise I think NI should give some consideration to the
basic functionality of their low-end digital stuff.
All the best
Andy
Message 6 of 26
(4,495 Views)
Port Write allows one to write to a particular bit or a set of bits with Line mask.
i.e if your are writing (set) to Bit 0 of a port
Line pattern = x1
Line mask=x1
likewise for reset the bit
Line pattern = x0
Line mask =x1
And, with Port write, it eliminates the problem of having the entire port reset. Line mask is allowing particular bit(s) to be changed leaving the rest untouched.
In conlcusion, NI's DIO is still doing well. Read the help context, get helps from NI FAEs.
regards
Ian F
依恩与LabVIEW
Message 7 of 26
(4,495 Views)
Hi Ian,
my mistake - I was using ''Write to Digital Port.vi' from the Digital /O
palette, didn't think think to look in the 'Advance Digital I/O' palette -
appologies to NI. Now it all makes sense I can use named channels as well -
makes my vi's much easier to read.
Thanks, and all the best
Andy Buchan
Message 8 of 26
(4,495 Views)
You are most welcome. And, hope that you will have great experience with NI's DIO capabilities.
Tell me how much my answer helps you by rating it ya.
Cheers and all the best
ian.f.k
MY/SG
Ian F
依恩与LabVIEW
Message 9 of 26
(4,359 Views)
Hey,
the vi`s which you have lay down here.. thank you but I can´t open them. The Resource-File is missing. Can you send it again?
Message 10 of 26
(4,495 Views)
