Need help finding a control
I want to list all of the connectors on a board on a vi front panel (e.g. J1, J2, etc...). If the user clicks on e.g. J1, all of the pins on J1 will be displayed, like when using a treeview. The user will then be able to select multiple pins from J1 (e.g. he/she clicks on J1-1 and J1-3). Whatever pins are selected I will set high. I thought I'd be able to put multiple treeviews on my vi, one for each connector, but it seems that with a treeview no more than one selection can be made. Basically I need a control that is expandable and multiple selections can be made. Is there a control that does this?
Thanks and regards
(3,419 Views)
Could you please draw us a picture (text is fine) of approximately what you are looking for.
It sounds to me, if I read your question correctly, that a text indicator will do the trick.
For example:
Before:
J1
J2
J3
J4
After J2 selected:
J1
J2
Pin 1 -
Pin 2 -
Pin 3 -
Pin 4 -
etc...
J3
J4
This can be done with a bit of work using a simple string indicator, a table, a list, etc.
For a string indicator, you would detect the selection by either polling the selection and an "Okay" button, or using a mouse up event on the control then checking the property corresponding with selection.
List indicators may be easier to work with programmatically, but I don't know if they are any cleaner looking. I suspect they are
probably the same. I can whip up a simple example if you wish...
I hope this helps
-Mike Du'Lyea
Advanced Test Engineering
http://advancedtestengineering.com
(3,419 Views)
Will this help?
ian"
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
(3,419 Views)
Hi Mike,
The representation you created is perfect. I understand what you are saying but if you could provide an example that would be great. Thanks.
(3,419 Views)
Thanks Ian, that works great.
(3,419 Views)
great. tell me how much it helps by clicking on the stars 🙂
Cheers and have fun
Ian F
依恩与LabVIEW
(3,419 Views)
