How can I wire two identical vi programs and run simultaneously (8 channels)?
I finished wiring my program using synch-shared timed based example. Since I have changed a couple of things to fit my program, how can I make sure that the data I'm collecting are synch? (Please note that I'm using RTSI cable)
Message 11 of 13
(659 Views)
Wiring the same signal into all ports should result in a over-lap of the data if all channels are sync'd.
There will be a phase shift if they are not.
Ben
Message 12 of 13
(654 Views)
Hi Ben,
I'm not really sure what you mean! could you please explain more details.
AD
Message 13 of 13
(643 Views)
