How can I use a variable in dll?
I have known how to call a function in dll with Library function node。
But the dll file I am going to use contains some variables which I need. But the LIbrary function would not work!
Would  Code interface node work? I have only a limited knowledge of C++. So I am wondering it.
Thx for any suggestion Smiley Happy
(5,518 Views)
Hi youminbuluo,
can you give some more informtation please? Is it your own dll? Can you change things inside of it? What have you already done?
Mike
(5,513 Views)
A CIN is a different beast. CINs are obsolete technology, so you should not use them unless you absolutely have to.
You cannot "access" variables inside of a DLL. You can only call functions. Furthermore, LabVIEW only handles C-type DLLs. If you are programming in C++ then you need to make sure you're correctly exporting the functions.  Have you looked over the LabVIEW Help? You should also read over this article: Writing Win32 Dynamic Link Libraries (DLLs) and Calling Them from LabVIEW.
(5,500 Views)
MikeS81. Yes, I have have give more details on this. But I was so sleepy yesterday.
I don't have the source code of the dll file. It is provided by hardware manufacture. I only have  .h, .lib and .dll file. It is thought to be enough,right?
I have post the h file here.
What I have done is wrap those functions like  "extern CIDLL_API BOOL WINAPI CIUsbLinked(void) " in labview. I can do that through Tool->Import->Shared Library(.dll). But to those variables such as "extern CIDLL_API BOOL UsbInited", I haven't figure out how to use them in my labview program. Those variables are important because they show the real time state of the hardware.
(5,477 Views)
Yes, I know that. I have read the first 14 chapters of LabView for everyone.Smiley Happy
The author has the same opinion with u. But I really have to use the dll which originally developed and used in Visusal C++
And for anyone who has the experience with such situation, I have attached the whole dll file and its demo, which is used in Visual C++.
 http://dl.dropbox.com/u/396791/Eg.rar
(5,475 Views)
Accepted by youminbuluo
You will need to create a wrapper DLL that contains functions that allows you to return the values of those variables. Your wrapper DLL would be used to call the functions in the manufacturer's DLL.
(5,463 Views)
So much thanks!
It is exactly what I need to do and I have succeededSmiley Happy
(5,449 Views)
