same object size (front panel) with different screen resolution
Hi everybody,
I realised an application, and I try to instal it on various computer. The probleme is that they haven't the same screen resolution, so the front panel is not the same on each computer. It is possible to build an application which have the same front panel with different screen resolution ?
Kriss.
Message 1 of 8
(4,217 Views)
Hi Krisss,
switch off any "adapt to screen resolution" switches in the VI properties...
You should also define "same front panel" and "same object size"! Do you mean the same pixel size or size in mm or size in percent of screen?
Message 2 of 8
(4,212 Views)
The best is to have the same size in percent of screen. That's way, all front panels are similar on each computer .Because currently I must resize the front panel for each computer...
Krisss.
Message 3 of 8
(4,195 Views)
And thank's for your quick answer GerdW.
Krisss.
Message 4 of 8
(4,193 Views)
Hi Krisss,
so you want the opposite of my first suggestion:
Switch on the scaling option in the VI properties.
But be warned of strange font (or other) scaling problems...
Message 5 of 8
(4,187 Views)
I tried it with Labview 8.6 but it doesn't work correctly. I try it with labview 2009, perhaps it's better. I will tell you the result tomorrow.
Message 6 of 8
(4,175 Views)
Hi GerdW,
It doesn't work correctly with Labview 2009 too. With this method the front panel (and the objects) are distort. So I think the best means to resolve this problem is to create one front panel per screen résolution that we use.
Thanks for your help GerdW.
Kriss
Message 7 of 8
(4,158 Views)
If you really need this to work, you can do the rescaling yourself.  Use the Panel Resize event on the VI to signal that you need to resize your objects.  Use VI server properties to resize things.  You can find an example of resizing things and more tips here.  Let us know if you need more help.
Message 8 of 8
(4,139 Views)
