How can I programmicly modify a ring control?
I have a test system that supports numerous products. In addition, I frequently have to add new products to the support list. I have a ring control that lists those products. I would like to be able to have my program automaticly read a setup file and modify and/or add to the ring control list any new products found in the setup file. I am wondering if anyone has attempted this. Or, is there a better way to setup a adaptable system to accomidate what I want to do?
Message 1 of 8
(3,849 Views)
This is very easy. Right click the ring control, create a property node
"Strings[]" (Create>Property Node>Strings[]). Put the desired names in it
through this property node.
Wiebe.
Message 2 of 8
(3,841 Views)
Accepted by johnfr
In the diagram I attached I add an item to the Company variable, and set the value to the new addition.
Tim Elsey
Certified LabVIEW Architect
Message 3 of 8
(3,835 Views)
Hi Tim,
I just wanted to offer a tip to help you collect more Kudos for your postings.
1) After you post with an image attached right-click the link for the image and select Properties and copy the URL.
2) Use the Options drop-down at the top right of your post and choose Edit
3) Put your cursor where you wan the image to appear and then click the "Insert/Edit Picture" button (looks like a tree).
4) Paste the URL you copied in step #1 into the URL field and click insert.
Post your edited post.
Just trying to help,
Ben
Message 4 of 8
(3,814 Views)
Thanks for your responses. I have it working.
Message 5 of 8
(3,813 Views)
"Ben" <x@no.email> wrote in message
news:1235585420828-860249@exchange.ni.com...
> <img
src="http://forums.ni.com/ni/attachments/ni/170/389769/1/untitled.JPG"
border="0">&nbsp; &nbsp;Hi Tim,&nbsp;I just wanted to offer a tip to help
you&nbsp;collect more Kudos for your postings.&nbsp;1) After you post with
and copy the URL.&nbsp;2) Use the Options drop-down at the top right of your
post and choose Edit&nbsp;3) Put your cursor where you wan the image to
appear and then click the &quot;Insert/Edit Picture&quot; button (looks like
a tree).&nbsp;4) Paste the URL you copied in step #1 into the URL field and
click insert.&nbsp;Post your edited post.&nbsp;Just trying to
help,&nbsp;Ben&nbsp;&nbsp;
Ben,
I think you've misplaced this post? No Tim in this one...
Wiebe.
Message 6 of 8
(3,786 Views)
author of post 3 is Tim.
Ben
Message 7 of 8
(3,778 Views)
news:1235650205508-860834@exchange.ni.com...
> author of post 3 is Tim.&nbsp;Ben
Ok, sorry, but this entire post does not appear in outlook... Have to start
using the web interface...
Wiebe.
Message 8 of 8
(3,771 Views)
