How can I programmatically handle error 1074388985
I have an automated system in which I'm multiplexing with a 8473 CAN-USB module and sometimes when I'm running I'll get the following error:
 Error – 1074388985 occurred at NI-CAN
Configure
Network Interface Object
(ncConfigCANNet.vi)
Possible reason(s):
NI-CAN: (Hex 0xBFF62007) You attempted to set a configuration attribute while the object is running. Solutions: Configure attributes prior to opening the object; Stop and restart communication as needed so that you can update configuration attributes.
This is caused when I open an object with ncOpen.vi and for one reason or another I can't close it with ncClose.vi before once again using the ncOpen.vi command. The only way I can correct the problem is to manually unplug the 8473 USB connector from the computer and replug it. Is there a way to programmatically reset the 8473 when this error occurs?
Thank you.
(3,594 Views)
Accepted by topic author chuck72352
(3,557 Views)
Hey you have already asked the question here and have been refered to the same article and you have told that it solves the problem.
(3,554 Views)
