Search 1D Array not working with Double
Can anyone tell why Search 1D Array function is not working as expected in the attached VI ?
Message Edited by ssingh1 on 26-04-2010 08:21 PM
Message 1 of 9
(6,001 Views)
Please do a search on "equality", "LabVIEW", "floating point", "I found a bug in LabVIEW!", "LabVIEW can't do math!"
Also,  http://en.wikipedia.org/wiki/Floating_point#Accuracy_problems.
The Search 1D Array works by performing equality comparisons.
I have another nickel in my retirement fund.
Message 2 of 9
(5,991 Views)
Search 1D Array uses an "equal" as comparation. It is always a bad idea to compare floating point numbers with equal.
There are plenty of threads on this forum covering this issue. (example here).
This is not a LV issue (see here).
hope this helps,
Norbert
Norbert
Expert: Geometry
Message 3 of 9
(5,989 Views)
The problem is the way floating-point numbers are represented in binary.  You can find many discussions on the subject of comparing two floating-point numbers on this forum.  One good explanation is at: http://digital.ni.com/public.nsf/allkb/B01682241DD825948625665100663F61
Message 4 of 9
(5,988 Views)
Welcome to the world of floats and doubles. The precision is good, but not infinite giving these symptoms every so often.
Qestit Systems
Certified-LabVIEW-Developer
Message 5 of 9
(5,981 Views)
The VI is right, btw. Increasing visible number of decimals you'll notice you compare 0,58723354278 to 0,587234 which will never be true.
Qestit Systems
Message 6 of 9
(5,972 Views)
Accepted by topic author ssingh1
Hi Singh,
The 2 numbers you have arent equal:
Number in array is actually: 0.5872335427799636, you can see this by altering the display format.
Its to do with how the double value is stored on the computer.
I use an array called 'Approx Equals' that compares numbers to a specified decimal place:
I have attached the 'Approx Equals' vi. As said you can specify the accuracy of the comparison.
Rgs,
Lucither
"Everything should be made as simple as possible but no simpler"
Message 7 of 9
(5,969 Views)
Dear Friends,
Thank-you very much for your prompt replies explaining the reason for Search 1D Array not working accurately with doubles.
With regards
Shourya
Message Edited by ssingh1 on 27-04-2010 10:47 AM
Message 8 of 9
(5,911 Views)
Dear Friends,
With regards
Shourya
Message 9 of 9
(5,911 Views)
