04-13-2022 01:26 AM
I built an executable from the DataFileViewer.vi (C:\Program Files\National Instruments\LabVIEW 2020\vi.lib\Platform\storage\utility) and put it on a PC that has labview 2020 runtime, UCAR DataPlugin for NetCDF addon and UniPlot Software DataPlugin addon installed.
When I run the executable I get the following error:
LabVIEW: (Hex 0xFFFFF600) LabVIEW cannot load the USI components the Storage/DataPlugin VIs require. These components are installed by LabVIEW and DIAdem.
Does that mean I have to install LabVIEW (IDE, not runtime) to be able to use this?
I think what I'm missing is the "NI USI" runtime but I can't find an installer for it.
Any suggestions?
Cheers, Tom
04-13-2022 01:35 AM
Ah, I found it on the LabVIEW install DVD.
pool/ni-usi-core...
Fixed
